yes i have seen them they are almost 99% same in design.
My DashCam Duo Review
Night time, the inside cam has IR camsâŚfaces look clear. Front camera does capture pretty good clear video at nights
Nice review!
Ya lucky bugger
Good review @Tank âŚthough its a bit troubling that the screen can mark so easily
Be useful to know if speed has improved when used via the app, which has been mentioned a couple of times as a bugbear for some Roav or general dashcam owners alikeâŚ
Yeah so I did some testing and it doesnât work with the app, its standalone so you have to pull the memory card to retrieve footage, unless if course they changed it for retail release.
As for the screen, I wasnât easy on it by any means and at times left it sitting on my dash after it came off the mount so it rolled around a bit. But that goes with how durable it is and that it still keeps on working. Scratches can be seen with it off, but once turned in you do not notice them, and most people wouldnât have this as they would install and forget it until needed
