i recently bought anker sound cor-pro and i played with it fully charged one night and the other day when i try listen a song no sound and Bluetooth also working some body please help me out
My anker sound cor-pro
Have you tried charging the unit to see if perhaps the charge had been depleted
yes i did so far nothing happen
That’s a very vague answer, have you tried using a different cable to charge it? Did you turn it on? Did you unpair and try to repair it to your device? Is your device volume turned all the way down? Many questions can be asked…
If it still has problems after you tested all the methods, please contact us via support@anker.com, we will help you to solve it!
