my anker charges up fine, but when i use it to charge my iphone it is not accepted / doesnt charge… apple has had many updates lately…have they shut out anker or is there an update from anker for my anker product? previously had no issues.
My anker charges up fine, but when i use it to charge my iphone it is not accepted / doesnt charge... apple has had many updates lately...have they shut out anker or is there an update from anker for my anker product? previously had no issues
of the dozens of Anker Powercore portable chargers, yours is which model exactly (product code not name) …?
I believe mine is PowerCore Essential 20000 PD
So your Powercore is not charging your iphone? Did you try a different cable?
So are you using a USB-A to Lightning or are you using USB-C to Lightning cable? How old is that cable and where did you get it (is it Anker).
Are you using a different cable to charge iphone from Powercore than when you are charging iPhone from a charger? If so, focus on the cable and if you have a known working good cable then try that with the Powercore if not yet done. Some cables also need you to press the power button after you plugged in cable (but don’t press power button before, I’ll explain later why)
