Multiple Eufy Spotlight Camera's
Has anyone connected multiple"Eufy Spotlight" cams to the same network? any issues?
Will they show up as separate devices in your device list?
thanks
Hi @lgarry you should be able to add multiple spotlights to your Eufy app, each showing as a different device as the hardware serial and ID would be unique (renaming would be a good idea).
