Motion sensor trigger recording on a camera
I have a barn that is out of range for motion detection from the EufyCam 2 on the house which can see the barn. Is is possible to mount a motion sensor on the barn and have it trigger the cam for recording the event? I think a camera mounted on the barn would be impractical as to cover the door you would have to mount the camera almost pointing straight down.
You could ask there too :
