I’m trying to find a way to be able to send commands to Alexa when I pair the Motion Q to my Echo Dot. I’m having a hard time making it work with Alexa which was the main reason I bought it.
I was able to pair the device with Alexa but I can’t issue commands to Alexa from the speaker. I was able to do this with Siri by holding the play button for 2 seconds and then I can say a Siri command and it works, but the same doesn’t work with Alexa.
Any idea if this is possible and how?
