Motion detection alert confusion with Eufycam 2
Dear Eufyteam,
The sound of the motion detection alert of my Eufycam 2 is exactly the same as that of other apps that are installed on my mobile phone.
Example: the Whatsapp alert is/ sounds exactly the same as the Eufy motion detection alert.
It would be great to be able to give these alerts their own sound, personlalizing it by either a tailormade sound(= I create my own sound) or one created by the Eufy team.
Grt,
CS
I believe on Android you can personalize them
Hi Ikari,
Thanks for remembering me! Totally forgot how it works.
Grt,
CS
I can guide you if you need help
Hey Ikari,
I figured it out. Thanks for the offer!
Grt,
CS
Glad you got it worked out
