Samsung made 1 just one phone, that had a bad battery. Yes it was a major issue, but apple have had just as bad issues, and a lot more than one!
Aside that.
If you want an easy to use phone, that dictates to you everything… What you can do, what you can download, what music player, what app source, etc etc, then go apple (
baaah (it’s a joke!))
If you want a fone, that uses 2019 technology, lets you do anything, however you want to do it. Then it’s android.
Only downside to android, and it’s been the case since the beginning of time… Android are slow at releasing software. But (and it’s a big BUT) there are less issues after the software has been released on Android, but apple do (to be fair) release updates v quickly and when they make an error, they are fairly quick to send out another update to correct quite quickly too.
As for taking photos… Very subjective
For flexibility, it’s definitely android
There are plenty of romours of spyware/malware but you never really see it, but apple have been attacked and vulnerabilities have been exposed, and manipulated.
It’s really your choice, and what you want to do with your phone, and how free you want to be, to do that on your phone.
