Microsoft Surface Pro 4 - Portable Charging Cable
So I recently ran into a problem when purchasing a Microsoft Surface Pro 4.
I can charge it via a wall charger supplied but it gives me no opportunity to charge it on the go.
So off I go to figure out how I can piece together a portable charging solution, firstly I need a power bank to power it, Anker have that sorted and I bought a PowerCore 20100 which had the right ampage etc to get a full charge.
Now the issue, how am I going to get the power from the powercore to the Surface??
I found a cable online that has a 5.5mm Jack which I then had to buy a converter for to get a female USB connection to that I can connect it to the power bank. The quality is atrocious.
@Anker - Can you build a cable so that we can connect a surface pro to your chargers please?
