Mic not working
My anker soundcore liberty air’s mic is not working when I play games and record. It will only work when I make a phone call. Can anyone help me out?
I would recommend trying a reset. You can learn how to do that here.
If that doesn’t work I would recommend contacting support at service@soundcore.com
Perhaps others will have some suggestions.
Good luck!
Thanks but I tried doing that and it still doesn’t work ;(
It’s okay now its working properly now thanks for help anyways
did you do anything to get it to work?
yes please let us know what was the issue?
I restarted my phone and it worked.
Unlucky have you contacted anker support?
