All the eartips comming with the Liberty Air 2 Pro set doesn’t fit my ears well and also failed to the ears ‘fit test’ so the sound is not what it should be.
Looking now for memory foam tips which fit in the charging box during charging also.
Are there users of this set facing the same problems?
Please tip me if there are appropriate memoty foam tips for the Liberty air 2 Pro.
Thank you in advance.
Memory foam eartips for Liberty Air 2 Pro
As far as I know, Comply Foam seems to be the only brand to make foam tips for the Liberty Air 2 Pro. Here’s a link, if you’re interested.
They do fit in the case with the tips installed- additionally, here’s a Reddit thread/discussion about the Comply tips .
Hope this helps!
You can always some from Amazon
