@francisco_vazgarcia
Make sure to check the firmware is up to date on the Mars II PRO, can you give us the screenshot of the error for the Nebula Manager and the error code?
Also for iOS, Airplay is limited / restricted for Copyrighted content, and will not work. Does any regular photo or youtube music video work or any video on your iPhone work?
Certain content may be unavailable for screen casting due to copyright restrictions. In this case, you can play the content directly by using the same app installed on your Nebula Mars II.
Note that Mars II PRO comes with YouTube Installed, why not simply try playing the movie via Youtube App.
Please give it a try and let us know!!
Also it may be worth sending these questions directly to Nebula Support support@seenebula.com
