I was wondering if Anker carries a USB Charger that is able to have enough power output through the USB-C outlet to match the MacBook Pro charger provided with the laptop? If not is there one in the works to be put out on the market soon?
Macbook Pro 15.4"
If you pay attention to comments in Facebook or Twitter from Anker (Annie, Lawrence) then you see that a USB-PD higher Wattage product is in the works. No specifics and not dates. I don’t think the intention is to go upto 100W limit of USB-PD but certainly a step up from the current.
Personally though, if I’m in that mode of moving a lot and access to mains is not assured, I go with lower power devices, it shrinks everything down in size, the laptop, the charger, the battery.
