Lightest USB-C cable?
What is the lightest/slim 10ft USB-C to USB-C cable?
I use Anker Nano II 30W Fast Charger and Galaxy phone and would like to fast charge.
Is light weighted really so important?
I would use the most durable! :smile:
The weight of cables can be neglected in my opinion
I agree with @Chiquinho. The durability of the cable is the important part since weight varies in small amounts.
A nice braided cable like this one would be great.
this would be for my Camino pack, I do count grams. a few grams more is fine. thinner is better tho, not sure 100w is needed. thank you
The series 3 100w cable is the thinnest/lightest/compactable. It fits best in some tighter pouches I use. The same spec cables in series 5 are bulkier although rated to higher bend lifespan. All seem durable enough. The 6 foot powerline III cable is the lightest and thinnest Anker I have seen with 100W capacity. Wish that was released in a 10 foot but is only available in USB c to a and USB c to lightening. The 643 flow silicone is very amazingly flexible. It is a tad bulkier than the powerline III but the way it can coil and uncoil is quite impressive.
