Life P2 Mini Help.
My SoundCore Life P2 Mini charging case got left in my pocket and went in the washing machine, will they be fine and okay to use or do I need to go to a tech shop to get it repaired.
I would put it in an area to let it “dry out” where is no moisture. Even with this, the case may not work as it should. You stated about a Tech shop but depending on that price, I would send the service department an email to see if they have the case of the P2 mini for sale (as they have started letting you buy some item parts.
If so, it should probably be like 30 percent of the cost of a new bud. So if they are say 50 dollars then it would cost 15 dollars to buy.
So try to put it in an area and allow enough time for the inside to dry out and such…
