Life Dot 2 power issues
Bought a pair of Life 2s a couple days ago, first had an issue of the left earbud not powering on at all, now it randomly drops connection or just completely reboots, any known fixes?
  1. Confirm the charging case has power left
  2. Ensure all charging contact pins on the earbuds and charging case are completely clean and dry of sweat and water. Then put earbuds correctly into the case. (use kind of cotton swabs with alcohol to clean the contacting pin both on earbuds and charging case, and make sure the contacting pins aren’t stuck.)
    When you put the earbuds back into the charging case, the breath white to indicate both earbuds are charging normally.
  3. Connect the case with the included USB-C cable and plug it into a USB power source.
