I find that I have to double tap a few times to get it to stop…Am I doing it right? I understand that you have to double tap at a certain speed or it won’t work.
Can someone else how easy they find to pause and play?
Liberty Air touchpad sensitivity?
As far as I’m aware it should be a standard double tap, press and hold for 2 sec would skip tracks.
Have you tried a fresh pairing to see if this resolves?
It doesn’t work for me all the time…I’m just wondering how sensitive the touch pads should be…I find that don’t always work the first time…maybe the 6th or 7th.
I’ll try re-pairing . Maybe that fixes it…
Maybe you got a defective unit, it works fine for me. You don’t need to actually “tap” it like the AirPods where it needs a physical vibration to detect it, this is a touchpad so it reacts on simply lying the finger.
I even found it too sensitive activating even when I don’t want to (i.e. I take the headphone out of my ear with my hand).
I saw the Unboxtheraphy review in them and Lou mentions it take a little to figure out the double tapping.
Could the smudges (and the buds are a smudge magnet) be interfering with the touch sensitivity?
Bump… Just thought I would bump it…
