Hi guys, anyone notice the sound quality of the Liberty Air ear buds getting worse? Recently noticed some buzzing at louder settings and some stereo sounds being way more noticeable than usual. Anyway equalise them to see if it helps?
Thanks
Thanks
I haven’t had this happen with my buds at all… actually had the opposite happen. I would assume your buds are defective in some way. I recommend you contact soundcore support at service@soundcore.com
Hope you get it all worked out!
