Greetings,
I got my Liberty Anker Air 2 I finally got it pair to my smartphone but when did that I can’t connect it now to my iPad when I cleared the settings so I could connect to my smartphone so now I can’t pair it to my iPad
Regards
Marko
Greetings,
Regards
Marko
Are you trying to connect Liberty Air 2 to your phone and iPad at the same time?
No I’m trying to pair my iPad back but when I pressed the charger button for 10 seconds to to clear the memory to pair to my smartphone it unpaired my iPad
Now I can’t pair my iPad the earbuds liberty Air 2 it doesn’t show on my iPad Bluetooth list
Ok in that case, try to reset the earbuds using the video below. Once done, try to pair with your iPad. Also if you haven’t already, try to restart your iPad as well
