Does the indicator on the headphones flash while listening to music? If so, can this be disabled?
Liberty Air 2. Flashing light
Ok just tested this out. While you have active music or a calling going they don’t not flash. They will flash when you change app or change between phone calls and music.
There isn’t away to turn it off as far as I can tell.
Many thanks! This is an important moment for me, I don’t like when something blinks and this attracts the attention of others. It’s good that the indicator does not blink when music is playing. But I hope that with the next firmware developers will give the opportunity to make it so that after connecting the headphones to the phone, it stops blinking at all.
