Liberty Air 2 - Call Aswering
When I answer or make calls with my Liberty Air 2’s connected to my iphone, my phone defaults to speaking through the handset instead of defaulting to the Liberty Air 2’s. I can manually change the call to be on my earbuds, but everyone complains that they didn’t know if i was on the phone or not for a few seconds.
Is this normal?
You have to change the settings on your iphone, it has nothing to do with the earbuds. Do a google search for what settjngs to change…
Edit, here are the directions:
  1. Launch Settings from your Home screen.
  2. Tap General.
  3. Tap Accessibility.
  4. Scroll down and tap Call Audio Routing .
  5. Tap either Speaker or Bluetooth Headset. If you tap Speaker, it’ll automatically route to the iPhone’s speakerphone.
Thanks!
I also have a plantronics headset and it automatically defaults to the headse when it is connected, no need to change settings. I wonder if the plantronoics app automatically overrides the settings when the headset is attached.
Hey there,
I have the same problem, but I’m using my headphones with Google pixel 2xl. Could you please share how I could change the setting? It’s really quite annoying that it keeps transferring the call the phone itself… Thanks!
