I was looking to purchase one of these two earbuds seeing as the liberty 1 in white can now be found for just £50. The liberty 1 has a much nicer case in my opinion, but which one is better overall, and is there any issues with the liberty 1 that was fixed with the life P2? Overall which one should I buy?
Liberty Air 1 Vs Life P2
Liberty 1 you can only use the right earbud solo. Where as the life p2 you can use either the left earbud or the right earbud without having to have the other. Also the life p2 has two more microphones in them compared to the first libertys.
My suggestion is go with the life p2.
Seconding the points @Unnamed has mentioned…personally I would suggest the Life P2 (own them also)…
I own the Life P2, not the Air 1, and I cant really fault it. Left and right buds work seamlessly independently and together, audio quality is fine, phone calls working well.
Wireless buds overall suffer from far more likely lost or damaged as they fall out the ears to ground more often, so I’d urge not spending much £ on. You’ll be spending most of the time of your ownership of wireless buds having lost one of them so strongly encourage buying a type, like the P2 which has two independently viable buds.
Let us know which one you pick
