Am interested in an additional battery for the LC90 - anyone know the specs for that - and or which Anker power bank will charge it? Thanks
LC90 battery - backup
18650 batteries. There are plenty of good and cheap chargers for it, but if you want USB charging, one charger to get is https://www.amazon.com/Batmax-Universal-Intelligent-Rechargeable-Batteries/dp/B0777LMZNP/ . Keep in mind that the LC90 has a built-in micro USB charger. Any USB power bank can charge it since it uses a micro USB port. The Batmax is good for charging more than the one inside the L90.
@iroast reply yes in the case of the LC90 you don’t need a charger you can use the LC90’s built-in charger capability.
If you do want an external charger then these are ones I have and work well:
Dual to charge 2 batteries concurrently
Single
Anker uses a protected good quality 18650, consider getting also a protected good quality 18650.
From a competitor but it answers.
18650 are high powered cells that can be explosive. Protected cells have a small, thin circuit that prevent overcharge/discharge/shorts/etc. This will make the cells more expensive than unprotected ones: $8 vs $14 (roughly).
Thanks all!
