I have bought a used LC 130 and the switch with charging does not work anymore. It there a way to get a replacement part for it?
LC-130 replacement switch
you would have to reach out to support to see if they can sell or provide you with a replacement switch. alternatively you can look ebay just for switch caps and find one that would fit you can buy. just measure the diameter and thread spacing to find the size you need
