Is there a recommend Anker charger for Lenovo Yoga 7i laptop?
Laptop charger
I would says we need more specs of the 7i.
Does the laptop accept PD input. Many don’t.
If so what is its minimum and maximum needs?
If you come here knowing these, probably you need to go to a Lenovo forum first, or look up your specs, and paste here, then we can help.
What type of charger does it needs?
I know my 2020 T15 Thinkpad does. The yoga is even more commuter friendly and is very likely to safely use them.
