I’ve had my Nano for several months without any issues but about 2 weeks ago, I discovered that my iPhone 11 would no longer charge using the Apple-supplied charger or with my car charger. Is this a “thing”?
Issues with Nano
That’s odd, did you try using a different cable?
Do you really think this a fault of the Nano?
Try a different cable first and try charging another device with the Nano.
You could clean the sockets of the phone and this of the Nano as well.
It sounds like you may have lint in your charging port. Take a look and then try again.
