Is there any rules on Testing Products?
I would really appreciate any help since I am brand new to this community.
Usually there is a time limit that you have to post your review. I don’t remember seen any particular limitations.
Hi @bemac
Welcome to the community @bemac . Since you are new community I would highly suggest you check FAQ for any further questions you may have.
Regarding your query about if there are any rules with testing products. Yes there is. For the list of rules and criteria you need to follow please visit https://community.anker.com/testing_club/rules
Is this for a product you have already received or in general?
It normally depends on the rules of the testing event but on average you are requested to submit a testing plan, complete testing and submit your review within 2 weeks of receiving your item.
Thanks for your help. I might apply to the test a product out.
No, I was just wondering if I should apply to the tester program.
I will be looking forward to see your review on the tester product.
I wouldn’t see any reason to not. The testing events are always a blast (if chosen for it), just make sure to make your plan as original as possible. It definitely helps (as it did for me with the Nebula Prizm I was chosen for)
