Is there a dark mode on the Anker Community Website?
Thanks in advance.
Thanks in advance.
Hi Johnson,
Yes there is. To activate dark mode you need to navigate to your profile, select preferences in the first drop down menu, then interface in the next dropdown menu, and choose dark which is under theme category.
Hope this helps.
Wow! Thanks for the quick reply. I will definitely try dark mode out.
No problem. If you have any further questions please don’t hesitate to ask.
Like it, pretty cool.
