How do I create a screen synchronization from iPad with Keynote (key) to NebulaCapsuleMax (as a projection)?
IPad/Keynote to NebulaCapsuleMax
Hi There,
Thanks for your inquiry.
Could you please try the following steps?
- Make sure that your iPad and Capsule Max are under the same WiFi network
- Enable the Screen Mirroring on your iOS device in the control center
- Then the Nebula will show up on the device Screen Mirroring List
- Choose Nebula and once connected, your iPad screen will be displayed on the projection surface.
Hope this helps. Thank you!
Anker Support Team
