Infini Pro Firmware
Is there any way to check whether my Infini Pro has a firmware update? When I open the settings screen in the Soundcore app, this is what I see. Looks like some sort of corruption?
Separately, @AnkerOfficial, I wanted to ask if it was possible to enable sound feedback on the Infini Pro? I would like to be audibly notified with the unit turns on, connects or disconnects to BT, etc. I have the unit in a place that’s difficult for the remote to send signals to, so I’m never quite sure if it’s on or off, or in pairing mode.
Thanks!
Generally speaking, if you go to SOUNDCORE.COM , and click on the menu, you’ll see … UPDATE FIRMWARE
CLICK THAT
Then DOWNLOAD this.
Hopefully that helps.
