Indoor Camera for Homebase 2 ?
My setup is a simple Homebase 2 linked with externally fixed eufyCam 2 cameras.
I am considering fitting internal door sensors and motion sensors together with a eufy keypad linked to the Homebase. All seems pretty straightforward.
Can anyone recommend a suitable internal camera which would also link to the Homebase which i could use to view the interior of the property in the event of an alarm trigger?
Any help would be appreciated.
the indoor cameras currently do not connect to the homebase, so I would recommend o use either the 2c cameras or be prepared to use the indoor cameras with memory cards installed.
I personally have 4x-2C cameras installed inside the house and would much prefer to use that over the indoor cameras. I do have a pan and tilt camera installed, but I found I end up viewing the footage of the other cameras more often as they are mounted higher up and have a greater field of view
