Eufy’s RoboVac G10 Hybrid is available for just $209.99… That’s a tie for the lowest price to date! But that’s not all: You can also get a FREE Lumos White Smart Bulb 2-Pack with code EUFYBULBT (after adding both items to your cart).
Note: This is a very good price for a robotic vacuum with smart dynamic navigation.
Order on Amazon
Features & details
- Smart Dynamic Navigation: Advanced gyro-navigation technology allows for up to 2x the efficiency while cleaning. Complete a routine clean in half the time, when compared to a standard robotic vacuum.
- Hybrid 2-in-1 Vacuum & Mop: Combine sweeping and mopping for a deeper clean that will leave your floors sparkling! Note: we have engineered this RoboVac to specialize in cleaning hard floors only.
- Convenient Control: Give instructions by voice or using your phone via the EufyHome app, Amazon Alexa or the Google Assistant. Set detailed commands and receive voice reminders on how your RoboVac is performing.
- Slim but Strong: With 2000Pa of suction power, RoboVac G10 Hybrid delivers our most powerful clean to date. The Super-Slim 2.85” body effortlessly glides under furniture and into hard to reach areas.
- What You Get: RoboVac G10 Hybrid, charging base, AC power adapter, cleaning tool, water tank, washable mopping cloths (x2), waterproof pad, extra filter elements (x4), extra set of unibody filter, 4 side brushes, 5 cable ties, quick installation guide and manual, and our worry-free 12-month warranty.
