I accidentally washed my charging case with the headphones inside
I accidentally left my charging case with the headphones inside of my scrubs like an idiot. I tried putting them in rice for 2 days but I’m not sure it worked that well. Does anyone have any suggestions :tired_face::tired_face:
Hmm bad,
have you dried them by a hair dryer, then store them on a warm (not hot place)
Then clean all contacts.
There is really nothing more you can do,
Wait and pray.
Good luck!
What charging case and headphones were they?
If they won’t work, just order a new pair. Good luck though
1451510998_original
Awesome job, you should be a moderator :clap::+1:
