Just wondering how do you use the rewards? When I click on my profile I see under rewards I have a $5 from welcome rewards but it doesn’t really say how to apply that and it show the status as Unused. It have the date from 3/14/2016 ~ 06/30/2017.
How to use rewards?
I’ve not used mine. When I try it causes the price to go up! Only available from AnkerDirect, they charge more in postage relative to Amazon its of no value.
To use, find something in products you want to buy which gives an option other than Amazon, then add to basket, go through checkout and you see your $5 and click on it to use.
Example
It will most likely be more expensive than Amazon (if you have Prime, of course) UNLESS you are spending more than $33 (before the discount), in whichcase it should be at least $2-3 less! Hope this helps!
thanks for the reply was hoping it would be a code that you can enter through Amazon for the discount oh well
I’m from UK and for some reason my vouchers are in Dollars and for US website.
