How to turn off SoundCore life 2 blinking light while in operation.
Hi
The constant White light blinking while “SoundCore life dot 2” is in operation is an annoyance to people around me. This also seems like bad design in terms of energy efficiency.
How do I turn off this blinking light when the earBuds are in normal use
Thanks,
Arun
You can’t turn it off. There has been several people complaining about it at community.soundcore.com but we have no idea when Soundcore will change that. If you have a Life Dot 2 (not NC), then you’re just stuck with the blinking light
As @Shivam_Shah mentioned, they can’t be turned off. I’d prefer the the lights to turn off as well. I’m not recommending it but you might be able to find a way to do a temporary cover of the lights when needed.
Put a small piece of tape over the lights
Jk lol
