Has anyone done this?
Got a new Soundcore Flare and while it sounds good, i partly bought it because of reviews saying it could be paired with an Amazon Alexa device. I have an Amazon tap with Alexa and…well, that pairing is not easy, at least for me.
I’ve looked for instructions on line, but always get stuck where it says…go to your device’s Bluetooth settings and connect from there. Neither the Flare nor the Amazon speaker has any Bluetooth setup onboard, other then pushing a button to put them in pairing mode.
The Soundcore app has no way to connect to a remote speaker and the Alexa app has no way to connect to an external speaker (other then the “go to your device’s Bluetooth settings and connect” which makes no sense to me.
Can anyone help here?
