How to increase motion detection range in pro 2k cam
Hello,
can some please explain to me if I could increase my motion detection range in pro 2k cam? my cam is mounted on the top of my front door. it is 9 feet high from the ground. it can only capture movement within the range from 15-20 feet max. Sometimes it is late to pick up any motion from 20 feet. I would say 15 feet works fine but not 20 feet. Do you think if I connect it with a power cord, this motion detection range would increase. My wired arlo pro 2 can do that easily from 25 feet. I am trying to switch to eufy since they offer all these AI features for free. Any feedback will be highly appreciated. Thanks
Angle your camera so that it picks up detection going across the field of view for the camera sensor. Motion detection is best and at the farthest range going across the lens light from left to right and vice versa
@Sajib.islam11 Power cord may not make any difference in detection as it was originally designed to be a Battery powered. You need to tweak few settings and test it to get the most out of it.
Go to eufy security forum and below is an excellent article on how to set up the motion detection.
A list of Tips & Tricks may help you as well:
