How to Edit Nebula Home Screen (Android 7.1)
I recently got a Nebual Apollo running Android 7.1 with the Aptoide app store. I got it connected to my Synology NAS using the DS Video app. The only annoying thing at this point is how to navigate to that app. When I installed Hulu, it automatically appeared on the list of apps on my home screen. After installing DS Video, it didn’t, so the only way I can find it is by navigating to the Aptoide store and looking at My Apps. Is there any better way with this OS and it’s dependence on the Aptoide store?
I have the capsule on Android 7.1, and for most part the interface should be exactly the same. Will give it a try today to see if this can be done and let you know.
You can also navigate to the apps, by Settings, App Manager. I have very very few apps - and these show up on the main page. Do you know have a lot of apps installed…
One trick is ( i know it is not a great one :frowning: ) – install the most important app FIRST on the Nebula projector, it comes on the first page, and the more the apps - these get moved / hidden.
Also, it may be a good idea to reach out to Nebula Support support@seenebula.com
Thanks. The only apps I have installed are the defaults (Amazon, YouTube, Netflix), DS Video, and Hulu. I’ll try support as well.
