How do you reboot the EufyCam E? There is a Sync button but not an On/Off button.
More generally, is there a User Guide online for EufyCam E? I searched and did not find one.
Thank you.
Thank you.
Why not going to your cams settings in the app and turn it off/on?
that does not do a reboot of the cam, that just turns off active monitoring but the wifi is still active.
The only way i know to reboot it, is it use the reset pinhole button underneath and then resync to your homebase
But this is not reboot either, rather reset to factory default settings. I didn’t read the existing manual that close but some one was saying they press sync button 5 times?
