How do I get a manual for AnkerPowerCore III Elite 25600 60W
I want to get the manual for the above named device
A1290
I searched anker.com support and neither 25600 nor A1290 found it.
So forced to email support@anker.com with product code A1290 and ask for copy of manual.
These items are so very simple either no need for a manual or find something similar and it likely operates identical / similar.
It’s a PD product so likely behaves like any of the PD products such as the 20000 PD
It’s manual
I found it on the AnkerJapan site (not sure why it’s not on the Anker site): :thinking:
Give that man a Solution!
