The Environmental Working Group (EWG) has released a new report on the effect cell phone cases have on the amount of radiation your cell phone emits. The study speaks to the concern that cell phone cases can weaken the phone’s signal including wifi & bluetooth and actually increase the users’ radiation exposure as the phone tries harder to communicate.
I experienced it my self (can be seen in my reviews soon) and found noticeable drop in cellular/wifi and bluetooth signals resulting the distortion while using any of BT hands-free. Phone signals are also down by 8 to 12 db.
So if you have complins about BT connectivity try to remove the protective shell/case of your phone.
I used different protective cases including metal protective armour, book cases, TPU, gel, plastic, rubber & silicone etc. The best signals I get is without any protective case and front protective glass.
The 2nd best result was with a case that just covers the sides of the cellphone while the top and bottom of the phone is exposed.
I am attaching the pictures of different cases along with the dBm readings.
While I am getting
-75 dBm without any protective case / glass protector.The other cases
shows more lesser readings like &The case with the most negative reading is an armour case with a reading of -93 dBm
