How can I get more powerbucks?
I am wondering how I can get more powerbucks? I see all the benifits of having and using them, but I’m not sure how I can obtain more. Anything is helpful! Thanks in advance!
If you go to the power draw tab and click the how to win and then earn power bucks it shows all the ways. You also get power bucks for leveling up and being active and through some give always Anker.
Thank you!
Check the power draw guidelines.
Not by starting topics that are already active.
