How can i control soundcore mini 2 volume through my pc
I got a pack of soundcore mini 2 a few days ago.
It was good, well-connected with pc, good ture wireless stereo mode and its volume could be controlled through PC.
But Its volume cannot be controlled by PC but only by the speaker itself. Else is good.
I got several reconnections BT with PC and had it factory-reset.
If you are using Windows ( which I believe you do) you should be able to control from Windows Audio control from system tray.
There are multiple apps you can use to do Control audio output on Windows. One app you could try is EarTrumpet. There may also be a msi / installer if you have Windows 7, but never tried.
thanks for your kind reply.
I have already been using EarTrumpet, but it doesn’t work, too.
