How can I change camera angle?
Is it possible to change camera angle. I want to avoid that I will get alerts when people walk to my neighbours door.
@Hans2 You can only change the angle by aiming the camera to the area you want to cover. The cameras have a very wide field of view (140 degrees.) There is no other way.
Piece of tape!
I used to do that on an older CCTV, and light sensor in my back garden.
Small piece of gaffer tape over the lens will stop it… best way to cut ½" wide by 2" long piece of tape should do it
