how about a universal laptop dc adapter with USB-C PD with connectors for all Laptop Brands
how about a universal laptop dc adapter with USB-C PD with connectors for all Laptop Brands with 45W / 65W / 90W / 120W
You mean this?
grafik
i mean something like this
I think I already pointed to it, so you want USB PD and laptop?
They sell PD chargers now and so when they also sell the cable it comes with universal adapters to take the negotiation of PD from the port to the cable.
I can’t find an English review, closest I can find is (enable CC and translate to your chosen language) the translation is not perfect but I get the general direction of the product, put the tip for your laptop on and it converts PD to laptop.
thanks for the detailed information … now i can check the review for further details
I have not seen any reviews. It was announced and “coming soon” is all I have seen.
There is no way this can do DC-DC conversion, so it can only support the voltages of the charger you use. It also frankly looks too thin to be 100W as that is 5A which needs to be about 70% thicker. I suspect it is just having the simple electronics to tell the charger which mode to select.
The photo looks like its not interchangeable barrel, so it may be a totally different product for each barrel size.
But it sounds like what you were seeking.
yes that was what i am looking for. thank you :slightly_smiling_face:
@AnkerOfficial can this be offered for testing, I’m keen on it being tested by people with a need so it gets appropriate use.
I don’t need it but @produktpodium sounds like does.
a chance to test it and make a review about would be great
