Hotspot for Eufy 2c
Hello,
Can I hotspot Eufy 2c security camera set or do I need to get internet connected to the house?
You need an ethernet cable to router to setup then you can unplug the ethernet cable and setup wifi so I think you need an internet connection first.
Eufy 2c connects over non-Wifi radio to the homebase.
The homebase connects to your Wifi or Ethernet to the Internet.
HI, I am a newbie. Just ordered a 3 cam 2c kit for my boat last night and won’t arrive until 3 weeks. I have a 4g router and was wondering would using Google home or Alexa screens let me view videos on the same local network without using the internet?
@menogue747 No! The eufy HomeBase2 Only uses ethernet or wifi to transmit data there is no other option to be able to do this. I hope you did not buy these cameras with the assumption of being able to. Hope this helps :v:t2:
