Homevac H30 suggestions
Couple things id like to see with the new Homevac H30… Having a clip or some sort of locking mechanism, even if its not on the unit by default… so the vacuum doesn’t fall out of the stand/stays on the charging pins… also the powered attachment doesn’t really sit in the cradle properly, perhaps a plastic adapter that will make one of the dock connectors deeper and allow it to not fall out due to the power connector… Am interested in the option for additional battery packs … would like to see the charger have a status LED that changes once the pack is completely charged…
Possibly a 12volt car adapter to plug it or partially charge it in a vehicle as an option?
Good suggestions
