Poorly designed vacuum cleaners, similar to the messes they should clean up, come in all shapes and sizes. They can be heavy and bulky but offer little power or are light and portable with no power. They have inconveniences to deal with such as dirty dust bags to remove, long cables, or terrible battery time if cordless.The list goes on and on.
HomeVac Duo 2-in-1 Cordless Vacuum, on the other hand, cleans well because it’s designed to GET TO the mess. The base unit is a highly-maneuverable stick unit that swivels around table legs, slides under furniture, and hugs walls. When spaces get really tight, pop out the built-in handheld unit to clean spaces an upright vacuum just can’t get to, such as the interior of your car, shelf space, or under couch cushions.
Simply getting to the mess but not having the power to clean doesn’t make a good vacuum cleaner either. That’s why HomeVac Duo is built with our Cyclonic System technology. It spins dust away from the motor, keeping it unclogged at all times, and maintains powerful suction throughout your cleaning session.
Not only is the HomeVac Duo a transforming 2-in-1 vacuum cleaner, its cleaning ability also does double duty in one pass. By using a HEPA-style filter, it traps microscopic allergy triggers such as dust mites, mold spores and pet dander, ensuring that expelled air is cleaner.
For cleaning sessions that go beyond a few bread crumbs, the 2200mah Li-ion battery powers through messes for up to 60 min, meaning you can go from vacuuming your house, to your car, and back to your home on one charge. Whether you just breezed through a little accident or spruced up your entire house, the bagless dust holder is released at the press of a button and empties clean.
With the HomeVac Duo in your hand, you’ll feel like you’re equipped to tackle messes with speed and gusto, while having the time of your life dust busting. What will you do with the time you’re going to save?
