Hello All
My HomeBase 2 Version wouldn’t like to connect my WiFi Network at Home, I figure out that my WiFi Password are not compatible with your system it means if a dollar sign „$“ included at at the WiFi Password the HomeBase 2 could not connect.
I removed the „$“ sign at my WiFi password and everthing works fine may there is a bug at the Firmware.
Firmware from the homebase 2 is 2.0.5.6 and subsystem version er 1.3.0.9
Did have anyone the same issue ?
Cheers
Thomas
