Hi all,
Just started with the Eufy products.
I have an indoor security cam 2k, it works fine with the Eufy app, I also have two EufyCam 2C cameras, they are connected to the Homebase 2.
My question is, to change the alarm staus from home to away I need to do the indoor and outdoor cams seperately, is there a way to connect all things to the homebase, or set all devices with one button?
Regards,
Mick
